Aloha!
I’m using an AC1300 WG Client installed in the home LAN through a dedicated cloud Wireguard VPN server. Everything works fine.
I decided to try using Flint 2 WG Server instead of the Cloud Wireguard VPN server.
- Generated a new certificate on Flint 2 for the AC1300 WG Client.
- The tunnel on the AC1300 does not come up (the orange indicator is on).
- Generated a new certificate on Flint 2 for the iPhone WG Client.
- Tested the operation of the WG Client on the iPhone via a cellular connection to the Flint 2 WG Server, and it works fine.
- Connected the iPhone with the WG Client to the Home WiFi (the same LAN where the AC1300 WG Client is installed), but the tunnel did not come up.
In summary:
- The AC1300 WG Client from LAN connects to the cloud WG Server without any problems.
- The AC1300 WG Client from LAN does not connect to the Flint 2 WG Server.
- The iPhone WG Client via cellular connection connects to Flint 2 WG Server without any problems.
- The iPhone WG Client from LAN does not connect to the Flint 2 WG Server.
I’ve tried everything I could. No more ideas left
