I want to connect my Glibox with my University VPN.
The CISCO Settings is here:
FernUni
IPSec gateway 132.176.101.101
IPSec ID FU-VPN-STUD-NAT
IPSec secret FU-VPN-STUD-NAT
IKE Authmode psk
Xauth username
Dead Peer Detection, send a packet every x sec
DPD idle timeout (our side) 120
I installed over the Plugin the VPNC and VPNC-Script.
I’m Login via SSH. And give these commands:
Enter IPSec gateway address: 132.176.101.101
Enter IPSec ID for 132.176.101.101: FU-VPN-STUD-NAT
Enter IPSec secret for FU-VPN-STUD-NAT"at"132.176.101.101:
Enter username for 132.176.101.101: xxxxxx
Enter password for xxxxxx"at"132.176.101.101:
sh: /etc/vpnc/vpnc-script: Permission denied
no response from target
root@GL-MT300N-V2:/etc/vpnc#
There is no /etc/vpnc/vpnc-script. Checking the ipk file I found the following.
root@GL-MT1300:~# opkg files vpnc
Package vpnc (0.5.3.r550-9) is installed on root and has the following files:
/usr/sbin/vpnc
/usr/sbin/vpnc-disconnect
/lib/netifd/proto/vpnc.sh
/lib/upgrade/keep.d/vpnc
/etc/vpnc/default.conf
root@GL-MT1300:~# opkg files vpnc-scripts
Package vpnc-scripts (20151220-2) is installed on root and has the following files:
/lib/netifd/vpnc-script
So you can do this to make a symbol link. Then try again.
