Vsim support for x3000 and xe3000
Did I read it right, that vsim support comes to the x3000 and xe3000 devices?
KR
Stefan
Hello Stefan,
Sorry the GL-X3000 and GL-XE3000 do not support VSIM at present.
Thanks for the answer. Sad to hear. Maybe in the future?
Hi @stoffel010170 , can you tell you why you want to use vsim with X3000/XE3000? I think you want to use portable and reliable data traffic, we have super sim card support your needs, do you think it can meet your needs?
This is our super sim card:
This is we can offer data plans, take a look at this data plan and see if it meets your needs.
https://w.simpoyo.com/plans/
I have a esim from GL inet and I'm fine with it. Without any physical sim it would be a nice feature. :grin:
telia super 12GB 10eu Telia SUPER Estonia prepaid SIM card, will work worldwide | eBay easy to refill whit there app
