Vxlan plugin broken on 4.11.0
I'm trying to play around with swconfig and vxlan but I get a error:
Thu Oct 22 05:21:59 2026 daemon.err modprobe: - vxlan
Thu Oct 22 05:21:59 2026 daemon.notice netifd: vx0 (5432): Command failed: ubus call network.interface notify_proto { "action": 0, "ifname": "vx0", "link-up": true, "tunnel": { "mode": "vxlan", "link": "wgserver", "local": "10.6.7.1", "remote": "10.6.7.2", "data": { "id": 678, "rxcsum": false, "txcsum": false } }, "data": { }, "keep": false, "interface": "vx0" } (Unknown error)
Thu Oct 22 05:21:59 2026 kern.err kernel: [93879.844125] module vxlan: .gnu.linkonce.this_module section size must match the kernel's built struct module size at run time
Thu Oct 22 05:21:59 2026 daemon.notice netifd: Interface 'vx0' is now down
Is this because of a kernel mismatch with the kmod?, if this get resolved, will this work both on the Flint 4 and Beryl 7 since they use completely different versions?
Thank you for your feedback.
We’ll ask the R&D team to check and see whether it can be fixed.
Regarding the compatibility issue between Beryl 7 and Flint 4, if you mean after both are updated to MTK SDK OP25, there should be no conflict—the kernel builds should be the same.
But if you mean Beryl 7’s current v4.9.0 version, it is still built on MTK SDK OP21 and uses a different repository source, so there should be no compatibility issue with Flint 4.
Just to update, we should have fixed this issue. Please try it and see if it works for you.
root@GL-MT6000:/etc# ubus call system board
	"kernel": "6.12.112",
	"hostname": "GL-MT6000",
	"system": "ARMv8 Processor rev 4",
	"model": "GL.iNet GL-MT6000",
	"board_name": "glinet,gl-mt6000",
	"rootfs_type": "squashfs",
	"release": {
		"distribution": "OpenWrt",
		"version": "25.12.6",
		"firmware_url": "https://downloads.openwrt.org/",
		"revision": "r33311-981c978eff",
		"target": "mediatek/filogic",
		"description": "OpenWrt 25.12.6 r33311-981c978eff",
		"builddate": "1792273538"
root@GL-MT6000:/etc# apk search vxlan
kmod-vxlan-6.12.112-r1
vxlan-7
root@GL-MT6000:/etc# apk search luci-proto-*
luci-proto-3g-26.201.70829~c8e1aa4
luci-proto-autoip-26.201.70829~c8e1aa4
luci-proto-external-26.201.70829~c8e1aa4
luci-proto-gre-26.201.70829~c8e1aa4
luci-proto-hnet-26.201.70829~c8e1aa4
luci-proto-ipip-26.201.70829~c8e1aa4
luci-proto-ipv6-26.201.70829~c8e1aa4
luci-proto-mbim-26.201.70829~c8e1aa4
luci-proto-modemmanager-26.201.70829~c8e1aa4
luci-proto-ncm-26.201.70829~c8e1aa4
luci-proto-nebula-1.8.2-r2
luci-proto-openconnect-26.201.70829~c8e1aa4
luci-proto-openfortivpn-26.201.70829~c8e1aa4
luci-proto-openvpn-26.201.70829~c8e1aa4
luci-proto-ppp-26.201.70829~c8e1aa4
luci-proto-pppossh-26.201.70829~c8e1aa4
luci-proto-qmi-26.201.70829~c8e1aa4
luci-proto-relay-26.201.70829~c8e1aa4
luci-proto-sstp-26.201.70829~c8e1aa4
luci-proto-unet-26.201.70829~c8e1aa4
luci-proto-vpnc-26.201.70829~c8e1aa4
luci-proto-vti-26.201.70829~c8e1aa4
luci-proto-wireguard-26.201.70829~c8e1luci-proto-aa4
luci-proto-xfrm-26.201.70829~c8e1aa4
luci-proto-yggdrasil-1.1.1-r1
It's not FIXED, this package is missing (luci-proto-vxlan)
Well, this post discusses VXLAN on Flint 4 v4.11.x, not on the MT6000, so the results may not apply.
Could you tell me the specific firmware version of your MT6000? v4.11.x-op25? We’ll then ask the R&D team to see whether the corresponding package can be added.
This is latest 4.11.2-op25
