VXLAN Support on GL-X3000 or any GLiNet device
Looking for one device to do vxlan over an ipsec tunnel.
Can the GL-X3000 support this?
IDK about over IPSec but here’s some promising links. You’re going to need LuCI at a minimum:
… the OpenWrt Forums are probably going to be the best place to get what 'ya need:
Thanks, I noticed that luci-proto-vxlan isn’t showing up as an installable option.
Is there a way to sideload a package?
LuCI -> System -> Software -> Software -> Actions -> Upload Package... should be the easiest. Expect there's probably going to be unmet dependencies required by whatever ipkg you're uploading.
You can also add addn'l feeds through Actions -> Configure opkg...
... but do make a backup of your current state if something goes sideways & ya gotta bail out:
I posted the same question over in the openwrt forums and they pretty much told me its not supported since version of openwrt isn’t supported by the device and I should speak with Gl iNet.
Oh, I see luci-proto-vxlan requires 22.03.0 while vxlan has a minimum of 18.06.0. Your Spitz AX is advertised as 21.02 (GL GUI → System → Upgrade).
Technically I suppose you could still do it without the LuCI interface… or hold tight until a future GL firmware drops. The next series are going to be based on OWRT 22.03.4, IIRC.
