MT6000, fw 4.5.4 r4 (2023-12-12 06:58:59), WAN connected by Eth1 + WiFi, Multi-WAN config: Enable Interface Status Track: disabled for all interfaces*, interface priority:
Despite a stable LAN connection to my hardware firewall I am kicked out every few minutes as soon as I connect WiFi, reason is a changed source IP (LAN IP vs. WiFi IP).
Pls fix, failover means WiFi mustnot be used when LAN is available (just imagine the failover line was a metered connection where I had to pay for traffic).
*help says
If tracking is disabled, the device will assume that the interface is connected to the Internet when the interface is connected (e.g. if a cable is plugged in and an IP address is acquired).
Does the same happen when you keep interface tracking enabled?
Why is it turned off anyway? In that case, only some hardware failure would be relevant - but if just the internet connection drops, the router won’t be able to understand it.
FWIW:
Rearranging Interface Priority and pressing [Apply] solves it until WiFi* is dis- and reconnected.
So some step appears to be missing in ifup/down or alike networking scripts.
* dis- and reconnecting Eth1 does not have this effect
