Why won’t my Mango connect to a TP-link access point for either an extender or WDS application?
can you share the tp-link device model?
Yes, it is model EAP110-Outdoor.
extender should work for all APs.
When setting up extender failed, can you still ssh to the router and get log?
Ok. The attempt to use WDS to the TP-link access point failed. I immediately ssh the MT300 and copied the log, which is shown below…
VICE): No such device
Wed Mar 15 16:27:09 2023 daemon.notice netifd: VLAN ‘eth0.1’ link is down
Wed Mar 15 16:27:09 2023 daemon.notice netifd: bridge ‘br-lan’ link is down
Wed Mar 15 16:27:09 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity loss
Wed Mar 15 16:27:09 2023 daemon.notice netifd: Interface ‘loopback’ is now down
Wed Mar 15 16:27:09 2023 daemon.notice netifd: Interface ‘loopback’ is disabled
Wed Mar 15 16:27:09 2023 daemon.err odhcpd[1453]: setsockopt(IPV6_ADD_MEMBERSHIP): No such device
Wed Mar 15 16:27:09 2023 daemon.err odhcpd[1453]: setsockopt(SO_BINDTODEVICE): No such device
Wed Mar 15 16:27:09 2023 daemon.notice netifd: Network device ‘lo’ link is down
Wed Mar 15 16:27:09 2023 daemon.notice netifd: Interface ‘loopback’ has link connectivity loss
Wed Mar 15 16:27:09 2023 daemon.notice netifd: wan (3235): udhcpc: received SIGTERM
Wed Mar 15 16:27:09 2023 daemon.notice netifd: Interface ‘wan’ is now down
Wed Mar 15 16:27:09 2023 daemon.notice netifd: Interface ‘wan’ is disabled
Wed Mar 15 16:27:09 2023 daemon.notice netifd: VLAN ‘eth0.2’ link is down
Wed Mar 15 16:27:09 2023 daemon.notice netifd: Interface ‘wan’ has link connectivity loss
Wed Mar 15 16:27:09 2023 daemon.notice netifd: Network device ‘eth0’ link is down
Wed Mar 15 16:27:11 2023 user.notice : Added device handler type: tunnel
Wed Mar 15 16:27:11 2023 user.notice : Added device handler type: Network device
Wed Mar 15 16:27:11 2023 user.notice : Added device handler type: bridge
Wed Mar 15 16:27:11 2023 user.notice : Added device handler type: veth
Wed Mar 15 16:27:11 2023 user.notice : Added device handler type: macvlan
Wed Mar 15 16:27:11 2023 user.notice : Added device handler type: 8021ad
Wed Mar 15 16:27:11 2023 user.notice : Added device handler type: 8021q
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[9908]: exiting on receipt of SIGTERM
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[10267]: started, version 2.80test3 cachesize 150
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[10267]: DNS service limited to local subnets
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[10267]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[10267]: using local addresses only for domain test
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[10267]: using local addresses only for domain onion
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[10267]: using local addresses only for domain localhost
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[10267]: using local addresses only for domain invalid
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[10267]: using local addresses only for domain bind
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[10267]: using local addresses only for domain lan
Wed Mar 15 16:27:12 2023 daemon.warn dnsmasq[10267]: no servers found in /tmp/resolv.conf.auto, will retry
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[10267]: read /etc/hosts - 4 addresses
Wed Mar 15 16:27:12 2023 daemon.info dnsmasq[10267]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Wed Mar 15 16:27:16 2023 user.notice root: drv_ralink_cleanup
Wed Mar 15 16:27:23 2023 daemon.notice netifd: Interface ‘lan’ is enabled
Wed Mar 15 16:27:23 2023 daemon.notice netifd: Interface ‘lan’ is setting up now
Wed Mar 15 16:27:23 2023 daemon.notice netifd: Interface ‘lan’ is now up
Wed Mar 15 16:27:24 2023 daemon.notice netifd: Interface ‘loopback’ is enabled
Wed Mar 15 16:27:24 2023 daemon.notice netifd: Interface ‘loopback’ is setting up now
Wed Mar 15 16:27:24 2023 daemon.notice netifd: Interface ‘loopback’ is now up
Wed Mar 15 16:27:24 2023 daemon.notice netifd: Interface ‘wan’ is enabled
Wed Mar 15 16:27:24 2023 daemon.notice netifd: bridge ‘br-lan’ link is up
Wed Mar 15 16:27:24 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity
Wed Mar 15 16:27:24 2023 daemon.notice netifd: Network device ‘eth0’ link is up
Wed Mar 15 16:27:24 2023 daemon.notice netifd: VLAN ‘eth0.1’ link is up
Wed Mar 15 16:27:24 2023 daemon.notice netifd: Network device ‘lo’ link is up
Wed Mar 15 16:27:24 2023 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Wed Mar 15 16:27:24 2023 daemon.notice netifd: VLAN ‘eth0.2’ link is up
Wed Mar 15 16:27:24 2023 daemon.notice netifd: Interface ‘wan’ has link connectivity
Wed Mar 15 16:27:24 2023 daemon.notice netifd: Interface ‘wan’ is setting up now
Wed Mar 15 16:27:24 2023 daemon.notice netifd: wan (10580): udhcpc: started, v1.28.3
Wed Mar 15 16:27:25 2023 daemon.notice netifd: wan (10580): udhcpc: sending discover
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10267]: exiting on receipt of SIGTERM
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10754]: started, version 2.80test3 cachesize 150
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10754]: DNS service limited to local subnets
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10754]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq-dhcp[10754]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10754]: using local addresses only for domain test
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10754]: using local addresses only for domain onion
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10754]: using local addresses only for domain localhost
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10754]: using local addresses only for domain invalid
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10754]: using local addresses only for domain bind
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10754]: using local addresses only for domain lan
Wed Mar 15 16:27:26 2023 daemon.warn dnsmasq[10754]: no servers found in /tmp/resolv.conf.auto, will retry
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10754]: read /etc/hosts - 4 addresses
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq[10754]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Wed Mar 15 16:27:26 2023 daemon.info dnsmasq-dhcp[10754]: read /etc/ethers - 0 addresses
Wed Mar 15 16:27:27 2023 user.info mwan3rtmon[2161]: Detect rtchange event.
Wed Mar 15 16:27:27 2023 daemon.notice netifd: Network device ‘ra0’ link is up
Wed Mar 15 16:27:28 2023 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Wed Mar 15 16:27:28 2023 daemon.notice netifd: wan (10580): udhcpc: sending discover
Wed Mar 15 16:27:30 2023 daemon.info dnsmasq[10754]: read /etc/hosts - 4 addresses
Wed Mar 15 16:27:30 2023 daemon.info dnsmasq[10754]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Wed Mar 15 16:27:30 2023 daemon.info dnsmasq-dhcp[10754]: read /etc/ethers - 0 addresses
Wed Mar 15 16:27:31 2023 daemon.notice netifd: wan (10580): udhcpc: sending discover
Wed Mar 15 16:27:33 2023 user.info mwan3rtmon[2161]: Detect rtchange event.
Wed Mar 15 16:27:43 2023 daemon.info dnsmasq-dhcp[10754]: DHCPREQUEST(br-lan) 192.168.8.133 b6:64:29:32:ec:de
Wed Mar 15 16:27:43 2023 daemon.info dnsmasq-dhcp[10754]: DHCPACK(br-lan) 192.168.8.133 b6:64:29:32:ec:de Galaxy-Tab-S5e
Wed Mar 15 16:28:04 2023 user.info : gl_health start->
Wed Mar 15 16:28:15 2023 authpriv.info dropbear[11746]: Child connection from 192.168.8.133:53748
Wed Mar 15 16:28:18 2023 authpriv.notice dropbear[11746]: Password auth succeeded for ‘root’ from 192.168.8.133:53748
root@GL-MT300N-V2:~#
As you use WDS/Extender, why the log still shows “wan” connection?
Do you have cable connected to the wan port?
There is no cable connected to the wan port. The Mango is brand new just out of the box.
This is still unresolved.
Pls use Extender, not WDS.
For the EAP110-Outdoor, is it using EAP (802.11x which requires username/password) or PSK/PSK2 (simple wifi key).
Mango does not connect to 802.11x network
