I just bought a Slate (AR760S). When I first turn it on and connect to it via 192.168.8.1, I don’t get the Web Admin interface. Instead I get a LuCi OpenWRT interface in Chinese. The username on the LuCi is root but I don’t know the password. I have tried ‘goodlife’ but it didn’t work.
What is the default password for LuCi? I have searched all over the internet but haven’t been able to find it.
I have also hard-resetted the router but I have not been able to get the WebAdmin interface.
I would be grateful for any suggestions or solutions to this problem.
Thanks for your suggestion. I tried that but it didn’t solve the problem. I managed to contact Gl.Net support and at the end, there was a problem with the firmware. I had to re-flash the firmware using Uboot. Thank again.
Hi, You mean AR750S?
There is no Chinese interface in LUCI by default. Is it your browser’s automatic translation or a firmware issue? Is it resolved now?
. I finally managed to solve the problem by replacing whatever firmware it was in the brand new router with the current AR760S firmware using the Uboot procedure. That solved the problem.
