hello, I installed the webcam on the USB port of the router AR300M16 it works very well, my question is: can I view the webcam on a browser of the Android phone, thank you.
Never tried it, but check out [OpenWrt Wiki] Webcam with the Linux UVC driver
I did an opkg list on my MT-1300 and all the packages mentioned there are in the repository, so good chance it might possibly work ![]()
Simon
Just spotted your hardware, it will be a slog for it!
Its not got full of CPU puff!
Simon
Here is a YouTube video on setting up a USB camera on OpenWRT:
You can view on a browser, but it is better to view the camera stream through one of the various Android apps (e.g., I have used tinyCam Monitor PRO).
If performance is bad, then you can try lowering the video resolution and/or frame rate.
Because it uses mjpeg format. So it depends on the browser.
I think you can.
