Webcam / video in AR750
Dear all,
I’d like some help with the following. I have a GL-AR300M were I can hook up a simple USB webcam and see the video option.
I would like to do the same with an AR750: hook up a USB webcam and see the video. I cannot get it to work and don’t understand why this seems different with another GL-inet device. My AR750 is running the latest version 2.272, I rebooted the AR750 several times. In the upper menu I see settings, app repo etc etc, but no video. With dmesg I see
usb 1-1.2: USB disconnect, device number 4
usb 1-1.2: new high-speed USB device number 5 using ehci-platform
but no devices like /dev/video . I installed usbutils, and see this with lsusb, so the webcam seems to be recognized by the kernel:
Bus 001 Device 005: ID 046d:0825 Logitech, Inc. Webcam C270
Any help please?
We removed this feature from all our new products (include AR750) and new firmware.
webcam is difficult to use in the router.
  • User experience is not good.
  • Compatibility is huge headache.
  • This feature will remain in DIY level forever, no way to commercialize
so you need to install and config mjpeg-streamer by yourself and DIY according to the guide in OpenWrt.
Thank you, I agree in the reasons and am willing to use mjpeg-streamer or motion or whatever. But I’m missing a device like /dev/video. Can it be, this support for webcams is also already removed from the kernel?
root@box:~# ls -al /dev/vi*
ls: /dev/vi*: No such file or directory
root@box:~# ls -al /dev/tty*
crw-rw-rw-    1 root     root        5,   0 Jan  1  1970 /dev/tty
crw-------    1 root     root        4,  64 Jan  1  1970 /dev/ttyS0
crw-------    1 root     root        4,  65 Jan  1  1970 /dev/ttyS1
crw-------    1 root     root        4,  74 Jan  1  1970 /dev/ttyS10
crw-------    1 root     root        4,  75 Jan  1  1970 /dev/ttyS11
crw-------    1 root     root        4,  76 Jan  1  1970 /dev/ttyS12
crw-------    1 root     root        4,  77 Jan  1  1970 /dev/ttyS13
crw-------    1 root     root        4,  78 Jan  1  1970 /dev/ttyS14
crw-------    1 root     root        4,  79 Jan  1  1970 /dev/ttyS15
crw-------    1 root     root        4,  66 Jan  1  1970 /dev/ttyS2
crw-------    1 root     root        4,  67 Jan  1  1970 /dev/ttyS3
crw-------    1 root     root        4,  68 Jan  1  1970 /dev/ttyS4
crw-------    1 root     root        4,  69 Jan  1  1970 /dev/ttyS5
crw-------    1 root     root        4,  70 Jan  1  1970 /dev/ttyS6
crw-------    1 root     root        4,  71 Jan  1  1970 /dev/ttyS7
crw-------    1 root     root        4,  72 Jan  1  1970 /dev/ttyS8
crw-------    1 root     root        4,  73 Jan  1  1970 /dev/ttyS9
In our Repo, search video and you should find some video kernel modules like the following
kmod-video-uvc
kmod-video
You need to install the webcam drivers.
