Hi, I run a webserver behind my AX1800 (Flint). I’ve enabled VPN for all devices (No VPN Policies). I’ve created Port-Forwardings from WAN to LAN for Port 80 and Port 443 to my webserver (say 192.168.8.xyz). It won’t work when I have VPN enabled.
I figured that when I have Internet Kill Switch enabled, connections from WAN to LAN and LAN to WAN will be blocked. Does that mean that when I have VPN enabled, all connections goes through another interface? Should I create a port forwarding rule from another interface to LAN? If so, which interface should I create? Any Firewall settings can I tingle to make it work? Thanks a lot.
