at the PC (connect with the VPN Client) runs a Webserver on Port 84.
the portforwarding on my homerouter are correct.
But i cant reach the PC via ddns.
Local it works.
from homenetwork it works.
Tests:
the webinterface of the MT300 via Ddns…Works!
but no Client behint the MT300
Firewall on PC are disable.
dosn´t work for me.
Fritzbox Forwarding ddns-> gl-inet IP with internal and external Port 112
Gl-inet Forwarding external 112 via openvpn to lan on port 80
Sorry, I still don’t understand your network topology. I have the following questions:
1.fritzbox is a routing device, ddns running on fritzbox?
2. VPN Server running on fritzbox?
3.client network (gl-inet) What is the IP address of this device wan?
4. You want to access the PC via ddns on the 192.168.112.8 device (192.168.18.201)
Yes and yes
Vpn Seerver running on 192.168.112.10
192.168.18.1
112.8 is a device at homenetwork and 18.201 are a device at clientnetwork.
