Weird keyboard issues since 1.7
I have been using the Comet for a while and I think this issue just started happening recently. Some keyboard keys do not work such as F11 and Cntrl-R. If I go to a local app, these keys/combos work.
For reference I’m using 1.3 rel 1 app and 1.7.2 rel 1 firmware.
Hi, Can you confirm your local keyboard and keyboard connected to controlled device work properly.
Please try if the virtual keyboard works fine.
try chrome ?
I did verify that the virtual keyboard works fine, I haven’t tried the keyboard connected directly to the remote machine yet
Ok, I installed Chrome on this pc and tried using that and it worked. I tried Edge and it still did not work as well as the windows app. Thanks
