Welcome to test AX/AXT1800 official beta firmware with kernel 5.4
For AXT1800
for uboot: https://glinet-forum-cn.oss-cn-shenzhen.aliyuncs.com/firmware/AXT1800-KERNEL5.4/openwrt-ipq807x-glinet_axt1800-squashfs-nand-factory.img
for web upgrade: https://glinet-forum-cn.oss-cn-shenzhen.aliyuncs.com/firmware/AXT1800-KERNEL5.4/openwrt-ipq807x-glinet_axt1800-squashfs-sysupgrade.tar
For AX1800:
for uboot upgrade:https://glinet-forum-cn.oss-cn-shenzhen.aliyuncs.com/firmware/AX1800-KERNEL5.4/openwrt-ipq807x-glinet_ax1800-squashfs-nand-factory.img (only UI3.x to UI4.0)
for web upgrade: https://glinet-forum-cn.oss-cn-shenzhen.aliyuncs.com/firmware/AX1800-KERNEL5.4/openwrt-ipq807x-glinet_ax1800-squashfs-sysupgrade.tar
Did it fix the wisp with 5ghz band + wpa3 issue? I can’t connect to remote AP that used wpa3.
Do not test wpa3,you can try it.
Why is this not on the official downloads site for Gl-iNet?
These firmware files were made by @robotluo and he only post them on our Chinese forum.
240038901 is a user of Glinet but not an employee of Glinet.
The firmware in the link is a test firmware compiled by me, which was originally intended for DIY users in China without a lot of testing.
However, since users have made the link public, they can also report back if they find problems during use
Is there an update available?
still no updates? it’s been a while…
Client (WDS) mode does not work with the 5.4 kernel
5Ghz AX is faster ingress, slower egress, the opposite with the older kernel.
~750 Mbit down, ~550 Mbit up with Intel AX200
There are much less TCP retransmission on Wi-Fi with the new kernel.
