What are my options for geolocation switching?
My goal is to have my location showing at my 2nd home. However, I don’t have internet at my 2nd home. What are my options for a setup at my main home to show my location at the 2nd home? Thank you!
you need 2 routers .. best a flint at home (no cg-nat) and a travelrouter like slate/beryl
the flint runnning as wireguard-server and the travelrouter as client.
you connect Internet at the second home with the travelrouter (phone+travelrouter) and connect
your Laptop with LAN-cable to the travelrouter. Now your IP-Adress Location
will show your home-isp Location, even if you sit anywhere in the world.
If you want do it the other way around, just switch the scenario. But you need Internet atg both locations, otherwise no communication between the devices is possible.
Properly a simple VPN-Service will fit your needs.
I am confused. As you don't haventer Inet in your 2nd home, how can you show its location?
