This is not an "issue", just curiosity.
GL-MT6000
The realtime graphs have a lot of different interfaces:
What kind of traffic goes through each?
Running ip -f inet addr show
gives me 4 - the loopback, eth1, br-lan and wgserver.
From that I can deduce that eth1
is the WAN interface and wgserver
is my VPN. I saw elsewhere that br-lan
is the bridge between the internal switch and the wireless radios.
lan1/2/3/4/5 are presumably the various lan ports. However the traffic I see on the active lan ports is much lesser than the actual outgoing traffic I see on on eth1
. I tried sending local traffic, but the lan# didn't budge. And if eth1 is the physical WAN port, what is eth0? It shows a similar graph to eth1, but always lower values and the direction is reversed.
I know some of the other ones are the wireless radios. And what does br-lan measure?
I see traffic on the following
br-lan, eth0, eth1, lan2, lan3, wgserver, rax0
(I think rax0 is the 5ghz radio, meaning ra0 is 2.4, and I don't see anything there because I have no 2.4 connected devices. lan2 and lan3 are the only wired ports I have plugged.)
I can run terminal commands if more information is needed.
