What is a good average upstream response time?
I see this stat in Adguard Home and I have no idea what it means. With ControlD as the upstream DNS, I'm seeing a response time of 47 ms. Is this good? What is considered to be good and excellent?
That's the latency it takes to get back the IP of the domain name you're looking up.
I typically get somewhere between 55 to 65 ms on Quad9 (on their malware filtering servers) over DOH but that's 'double NAT'd' — from behind another router before hitting the WAN — ~30 to 45/DOH on the edge, sorting algo/remote load dependent:
Wed Aug  6 09:29:08 2025 daemon.err dnscrypt-proxy[2299]: [2025-08-06 09:29:08] [NOTICE] -    35ms quad9-doh-ip4-port443-filter-alt
Wed Aug  6 09:29:08 2025 daemon.err dnscrypt-proxy[2299]: [2025-08-06 09:29:08] [NOTICE] -    36ms quad9-doh-ip4-port443-filter-alt2
Wed Aug  6 09:29:08 2025 daemon.err dnscrypt-proxy[2299]: [2025-08-06 09:29:08] [NOTICE] -    38ms quad9-doh-ip4-port443-filter-pri
Wed Aug  6 09:29:08 2025 daemon.err dnscrypt-proxy[2299]: [2025-08-06 09:29:08] [NOTICE] Server with the lowest initial latency: quad9-doh-ip4-port443-filter-alt (rtt: 35ms)
I can 'feel' ~90 to 100+ ms but your tolerance may be higher than mine. IIRC the best I've personally seen was < 30 ms (~25 ms?) using Cloudflare/DOH but I don't like Cloudflare. They hold logs for 24--48 hrs. No thanks.
Cloudflare's anycast DNS has a typical response time of a couple millisecond (I get 2ms).
If you are using WiFi that will add a few milliseconds.
If you are using LTE that will add +40ms.
Nice. Are those rates using DOH, DOT or clearnet? I assume it's an unfiltered upstream.
I'd love to know too.
a brief test, I was about 15ms.
I think the response time below 100ms is acceptable, the speed difference between loading resources is very small
