I have just bought an Opal router and hope to use the cellular option to connect to the internet. The list of supported USB Modems seems to have a lot of old devices on it.
Is there a best option for the UK or an updated list I can choose from at all?
(apologies if this has been asked before, I did search!)
This list, probably has not out of date? They all have tested by GL and our user, this is a good reference for you.
Are these models not available to purchase in the UK?
Thanks Bruce, Some models are available yes but most have been superseded by newer variants.
I have what looks to be a carrier badged Huawei e3372 but that doesn't work.
I have searched Amazon & Ebay and most are not available here it seems.
I may look at using a USB dongle that has WiFi and powering it from the Opal then connecting to it via the Opal's WiFi
Does work Vodafone UK USB dongle 4G
