iPad Pro 13 has 2752 x 2064. However, I can’t use full screen mode under Chrome and Safari. Can you suggest the best resolution (with EDID) for KVM in iPad Pro? Thanks a lot !
Sorry that using mobile device to access KVM is not support. Although it can see the image, there must have some question and are unreliable.
You can wait for our mobile app which is under developing but will not be released in the near future.
However, if you need, 2750x2064 has the ratio of 16:9, you can please try 2560×1440 , 1920×1080.
