What modems (4G module) can I use in Mudi (GL-E750) V.1 and Mudi (GL-E750) V.2?
Hello everyone.
I can't find any information in the datasheet about which modem connector Mudi (GL-E750) V.1 uses and which Mudi (GL-E750) V.2 uses.
Can I buy the US version of Mudi (GL-E750) V.1 and change the modem to Quectel EG25-G?
https://static.gl-inet.com/www/images/products/datasheet/e750v2_datasheet_20240108.pdf CAT 4/ CAT 6 ??
Is this PCLe or Mini PCIe ?
Mudi (GL-E750) V.1 --> PCLe or Mini PCIe ?
Mudi (GL-E750) V.2 --> PCLe or Mini PCIe ?
V1: mini pcie
V2: m.2
Quectel EC25 series is LTE CAT4 -> mini pcie.
Quectel EM060K series is LTE-A Cat 6 -> m.2.
Hello. Thank you very much for your answer. I will leave here a comparison table, maybe it will be useful to someone.
and it would be great if you could see this information in such tables so that the user doesn't have to look for
                  Mudi V2 -> m.2                     Mudi V1 -> mini pcie
Do I understand correctly that if I have MUDI V.1 then I can install any of the modems in this list?
Yep. If the module built-in by default can meet the needs of use, recommend using the default module.
Does anyone know how different in 4G/LTE reception and speed and also in wireguard speed are the EG25-G, EM05-G, and EM006K-G global modems?
CAT 4 module.
CAT 6 module.
The speed of CAT 4 and 6 can be Google, but the actual connection speed is related to your network environment, carrier, subscription fees, etc.
Fast cellular speed ​​will also get faster WireGuard VPN speed, but also the VPN client speed related to the speed of the VPN server.
Thank you for the reply. As you say, the interesting question is use experience, not category maximum found on Google. I hope someone has experience with these modems inside these devices and can compare.
Is the Quectel EG25-G used for Europe?
You can check whether the corresponding Band supports European operators.
Generally "G" stands for global, and can be used in most regions around the world.
Even if it is not fully supported, but can meet daily use.
Hello Bruce.
Thank you for your answer.
Sorry, but it's not logical what you suggest))
If I bought a MUDI V.1 in the USA and now I use it and plan to go, for example, to Europe, according to your logic, I should buy a MUDI V.1 with EG-25G)) :grin:
That's why I created this thread to understand if I can insert the EG-25G into the US version of MUDI V.1?
I can do it without asking, but I don't know if it will work or not.
I think it should be worked, as long as the modem is Quectel and cat4, and interface is mini pcie.
