I just bought a GL-X750V2 to use outside my home in a remote are because it supports band 71. I like to know what barrel connector size I need on the end that fits into the router. I already have a rechargeable external battery pack that has a
5.5mm X 2.1mm plug.
You will need an apprpriate cable to connect to the barrel connector on your X750.
The correct size is: 4.0mm*1.7mm
Wow that was quick. Thanks a lot sir
