What speeds are you getting with GL-MT300N? Maximum, normal, wifi, cable, anything
I have slow devices so I’m not sure what to expect, but I’m having really slow speeds by wifi (17Mbps maximum in a 300Mbps fiber connection)
Also to alzhao: there’s no “next page” button on the forum
alzhao
April 13, 2016, 1:44pm
2
@David , thanks for your feedback.
The wifi speed can easily goes up to 65 Mbps with my iPhone 6s on my 100Mbps cable network using speedtest.com
Maybe you can try using a different device or wifi channel.
I noticed there is no “next page” button on this forum. I want to shift to discourse or nodebb rather than modifying the code of wordpress.
justin
April 13, 2016, 9:18pm
3
I can also confirm that over Ethernet I can easily push 100 Mbps.
Do you have an android phone? I would get the app “Wifi Analyzer ”, and see if the WiFi channel your on is congested. Changing the channel to a channel with less networks on it should help improve speed.
I get wireless speeds of 38Mbps when the device is connected to the router by Ethernet cable, and 27Mbps when I connect it to the router wirelessly.
In case you’re interested, I get 5.2Mbps connected to a 256 bit AES encrypted VPN, and 7.8Mbps using 128 bits.
jrj
June 16, 2016, 12:08am
5
Down: 94 Mbps wired, 67.7 Mbps wireless. Up: both 12 Mbps…
