What would you recommend for a Wireguard VPN server?
Currently using Brume 2.
1GB fiber (both directions) has become available where I live. I currently have a Brume 2 as a VPN server. I believe it can hit a max of 350mbps as a server. I also have seen that the Flint 2 can hit 900mbps max. Is it really that big of a difference if the VPN server is used for connecting to a VM and VOiP where the server is located or is the 350 max “good enough” if that is all you are going to ever be doing with that VPN?
Bi-Di! That's damn nice. Humm... you should really enjoy this thread... & I do mean you should enjoy all 1.1+ Gbps over WireGuard. Grab a coffee. I think you'll find answers to questions you didn't even know you had:
Thank you for your love and attention to GL products.
I think using the Brume 2 you already have as a VPN server is a not bad choice.
In actual scenario, the situation is relatively complicated, if it can run to a very ideal speed, like 200+Mbps, that is pretty good speed.
Please make sure your ISP modem (or Brume2/Flint2) has a public IP to build a own VPN server.
