What's your dream GL-iNet Device? Here's mine
In short, my dream GL-iNet device has:
Long version,
I have 3x use cases that I’m currently trying to constantly fill around that this “Dream Machine” helps me achieve.
  1. I need good 5G modems that can connect to a 4x4 MiMo Antenna and provide internet to existing wifi networks in Pro-sumer residential setups (UniFi Network)
This is for my own personal home network. Right now I have that Ugly Tmobile 5G cylinder thing that doesn’t have an external antenna options (without modifications) and a equally ugly AT&T M6 Hotspot plugged into my network WAN ports for a load balancing setup.
I want these modems to be the same device, no frills with some upgradability and external antenna connections.
  1. I need good 5G modems that can connect to a 4x4 MiMo Antenna, act as a router and provide great mesh wifi networks in rural homes
Aside from my house, most of my friends and neighbors are in a terrible network area that only offers DSL and no “official” Cellular modem support. I’ve got them all sold on moving off DSL to a Mobile, but what device do I put them in? Cudy 5G? That’s kind of the only “consumer friendly” choice until GL-iNet crushes them with their own solution.
  1. I need good 5G modems that can connect to portable external antennas, act as a router, and provide great stable wifi network at long ranges (ideally 200 ft?) in a portable rugged form factor. OR a form factor that can be easily disassembled and placed into a different case.
I’m constantly going to Baseball / American Football / Basketball / Soccer Fields and setting up live streaming cameras / mike and equipment. I have to have a robust wifi network and preferably multiple bonded 5G connections (through Speedify) to ensure that I have a consistent and uninterrupted upload while also covering the venue in strong enough wifi so that my 6x wireless cameras can constantly stream their video signals in 1080p / 4K back to my production desk.
Dream on, I would say… Mine is just for one that works perfectly and reliably with no hiccups.
Frankly, I just want a Slate AXT-1800 Pro or something. One that can handle VPN speeds at 1gbps. I love using a VPN on the router, but it’s a shame that the internet speed generally gets cut in half😄
A travel router with quad-core (or greater) CPU, 1GB/2GB/4GB memory capacities, SDcard, 2 USB ports (1xUSB2/1xUSB3 would suffice), upgradable internal m.2 NVME slot + internal storage, 3+ wifi chips (2.4Ghz + 5Ghz +6Ghz for clients and dedicated wifi tether/mesh chip for bandwidth >1Gb to clients),1xWAN + 2xLAN ethernet ports, internal 4G LTE, external, 5G NR in an enclosure and USB-C PD power input.
I would also want to see GL.Inet release different size firmwares available for different use cases at launch (lean, normal, heavy, full) with different software/driver bundles in each (most current firmwares are normal, but throwing the advanced networking packages into heavy keeps a simplified GUI and having lean as a clean install for best security. Install everything plus the kitchen sink on full firmwares and call it alpha with no implied warranties.)
My memory/storage upgrades were from 64MB/16MB on an AR150, to 128/16(8GB extroot) with dual band on a Spitz, to 128/128 with gigabit on an Opal and to a 1GB/16GB RPI 3b+ for OpenWRT 22.x testing, with the frankenrouter listed above having all of the features I enjoy in a tidy package.
I can remove the antennas from my Spitz and fit all of it in a pocket using a USB3 to DC power adaptor, but if a router was any bigger, I’d just lug around a quad port mini PC with openWRT compatibility to get all of the upgradable features. Similar to this link.
Mango sized router with
  • Enough juice to handle 100mb down on wifi while on Repeater mode.
  • more storage space 32mb-64mb is enough.
  • 4G sim compatible or internal addon supported.
  • Ext Antennas
  • Type C plug for power, 2x rj45 ports.
  • Slightly bigger footprint is fine.
I use my router for multi-month trips to multiple countries. I would like something no bigger than the original Slate, with more RAM and multi-core CPU. Size and weight are important and all the new products are too big and too heavy.
Mango sized router with WiFi 5ghz, and dual gig eth ports, quad core, 1gb ram at a sub $40 dollar price.
Kind of like the Nanopi r2s, but with WiFi
Since I keep getting asked in messages…
I’m currently using Speedify on my Flint router to bond multiple hotspots. I loaded a custom OpenWRT firmware on it called SmoothWAN on to the router.
Works great so far.
