Please refer to following link.
https://dl.gl-inet.com/?model=ax1800&type=beta
My router is MT3000, what your means is MT3000 beta firmware?
[update] I download the beta firmware, still cannot find openvpn config, only zerotie, tailscale, where is the openvpn client config?
It has been mentioned a few times on the forums that the routers for the China market omit VPN. Is this the case with your router?
So, where can I download the oversea version firmware?
https://forum.gl-inet.com/t/brume-2-no-vpn-application-on-the-router/
@Alzhao may possibly be able to assist.
Sorry, I gave you the wrong link. What you need to see is the document in the link.
