Where to enter port number for GoodCloud Remote GUI Access
Hello
I'm using the new GoodCloud, like the new look, but it seems like I the option to manually enter the HTTP port when connecting to via Remote GUI is gone?
On the previous version, clicking on Remote GUI would pop up a window asking me to enter the HTTP port, and then it would connect, but because this window no longer pops up in the new UI, I'm getting an error when connecting to my devices.
Is there a way around this? Thank you!
I apologize for the inconvenience you've experienced. I'm pleased to inform you that this feature is now functioning properly on the cloud platform. You can access the router's WEB-GUI using the port number you have configured.
Thank you for the quick reply! I do see it now and it works. Thanks again for the quick turnaround.
