Which antenna is which? GL-AR300M
I am mounting my GL-AR300M-903-NOR in a waterproof box on the top of the aluminium mast of a sailing boat. One use for this is to get a better signal from the wifi in a harbour or marina. So I have one antenna vertically to catch the harbour wifi and one sticking out horizontally to get better coverage below on deck (the mast has a fairly wide aluminium plate at the top). So if I run the router in "Repeater" mode is one of the antenna go to the remote wifi and the other connect as a hotspot? In that case which is which?
Thanks
Bill Lionheart
(ps the box also has a Hwawe 4G dongle so I can get internet in coastal regions with no wifi but cellular coverage)
They are TX and RX the same time - so no dedicated antenna just for repeating.
