I want to use Easytether on my GL.iNet GL-AR300M16-Ext but don’t know what IPK file to use. Also do I use openwrt 19.07.3? Thank you!
On my GL-AR300M16, I use
easytether-usb-openssl_0.8.9-5_mips_24kc.ipk
Thank you, Did you update to latest firmware or used the stock one?
My router still has Firmware 3.203-0701 because I do not use it much anymore. It should be safe to upgrade to the latest firmware and you can reinstall an older version if necessary.
