Which ports are required for GoodCloud?
Is there a full list of ports for GoodCloud web access to the target GL-iNet router to allow remote management?
Found at that when we try to connect from GoodCloud to an router via Remote GUI, router will try to etablish an connection to destination port 59127 TCP. Is these the only required port?
Try disable forcing HTTPS for GUI.
I found out that GLINeT, despite using a tunnel to connect to router, it does use port 80 http webui.
