Which product
I would like to operate two lan networks behind my internet access. These networks should be completely separate. I would also like to have vpn for both networks. I would also like to exclude individual clients from the vpn. This is possible with the GL-MT2500. But the Brume 2 has only one lan port. Can I still create 2 networks here or do I have to use a different router.
If you want to create two wired network, you need to have two LAN ports.
Can i set up two separate networks with the GL-AX1800 and exclude individual clients from the vpn?
Yes. At least you can create Guest wifi which is in the router already.
If you can use Luci, bind the guest wifi to one LAN ports, then you will have two network.
