Puli has been packaged with several different modem models during its long production run.
Do any of the Puli modems offer IMEI mutability through AT commands or any other method?
If so, which modem model?
Thanks!
Thanks!
I am already reply to you in the PM channel.
Please contact our support team [email protected] if you have any AT commands issue, cellular expert will reply to you about this info.
Thank you.
I sent eMail yesterday.
Patiently waiting for a response.
Problem solved, as soon as I discovered that IMEI can’t be set while ethernet WAN interface is up.
