i try more than one time to can do a site to site configuration with some AR750.
i manage to do it with goodcloud, but i’m not able to do it working properly without goodcloud.
is it somebody was able to can do a site to site configuration with only openwrt or luci?
if yes could you give us a tutorial?
because each time i do it, i’m able to ping the server lan, but not able to ping the client lan!!!
i will try to do it.
but i’m pretty sure, some configuration are only with gls2s, and i’m not sure that the configuration can be available without this.
i mean, all the configuration done by gls2s, is not visible in luci.
