Insert usb in the router,connect to my router:
List all partitions on sda:
root@GL-A1300:~# fdisk /dev/sda
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 1230847 1228800 600M 82 Linux swap / Solaris
/dev/sda2 1230848 31948799 30717952 14.6G 83 Linux
I want to mount all content in /mnt to/dev/sda2
root@GL-A1300:~# mount /dev/sda2 /mnt
Mount is denied because the NTFS volume is already exclusively opened.
The volume may be already mounted, or another software may use it which
could be identified for example by the help of the 'fuser' command.
mount: mounting /dev/sda2 on /mnt failed: Resource busy
Is there on way to mount it?
