Why does dnscrypt cause the router to slow down?
Beryl ax, if I use any DoH or DoT or adguard with DoH, and run top in ssh, I find adguard or dnscrypt-proxy2 to be 200%+ of VSZ%, but always, after some hours, webpages will start resolving very slow, latency from main router will go from 30ms or less to 200+, and latency to any page becomes 800ms
was using 4.6.8 with these issues, tried 4.7 with same issues. no vpn in use. Just repeating main router's wifi.
I tested in my router and found that occasionally a few would over 1000ms, but most within 200ms.
DNS query latency is most likely related to the network environment and DNS server busy.
When the latency is high, will it improve if I restart it?
About the system resource, replied in your another thread:
