Why Does My Wi-Fi Keep Dropping When I Move Between Rooms?
Hey everyone,
I’ve been having a frustrating issue with my GL.iNet router, and I’m hoping someone can help me out. Every time I move between rooms in my apartment, the Wi-Fi signal weakens or even drops completely. It’s especially noticeable when I walk from the living room to the bedroom or kitchen. My place isn’t huge, and the walls aren’t particularly thick, so I’m a bit puzzled about why this keeps happening.
To give you a clearer picture, the router is currently placed in the living room, pretty much in the center of the apartment. I’ve tried different spots, even placing it higher on a shelf, but the problem persists. The connection is strong when I’m in the same room as the router, but as soon as I leave, it starts acting up. I’ve already rebooted and even factory reset the router, but no luck.
I’ve been thinking that maybe there’s some interference from other Wi-Fi networks in my building. I tried changing the channels in the router settings, but I’m not entirely sure how to pick the best one. Does anyone have advice on how to select the right channel? Also, would turning off the 2.4 GHz band and only using the 5 GHz band help? I’m a bit worried that it might make the range worse, though.
Another thing I’ve noticed is that the problem seems worse when multiple devices are connected, like my phone, laptop, and smart TV. Could it be that my router can’t handle all these devices at the same time? I’m not sure what the router’s device limit is, but I do have quite a few smart devices connected throughout the apartment. Has anyone else experienced this kind of issue with too many devices bogging down their Wi-Fi?
The reason I’m asking all of this is because I was recently reading about how people have solved similar problems by simply adjusting their router settings, and I felt inspired to see if that could be the solution for me too. I figured why not try the same before going for hardware upgrades or replacements?
During my search, I came across an interesting tool called the where am I tool online , which is designed to pinpoint your location using your device’s signal. While its primary purpose is geolocation, it made me think about how the placement of my router affects the signal strength in my apartment. Inspired by this concept, I’m starting to wonder if the Wi-Fi issue could be related to how the devices are positioned relative to the router and if tweaking the settings could solve the problem.
So, what do you guys think? Should I try adjusting the settings further, or is there something I haven’t thought of yet? Maybe I need to get a Wi-Fi extender, but I’d rather exhaust all other options first. Any advice would be greatly appreciated! Thanks!
If you are in a building with plaster or stucco which includes wire mesh inside the walls, that can have a big impact on wifi. This may well not be your problem, but it's worth a mention.
Lets start with:
  • which version do you use op24 or mtk, wlan-ap?
  • do it also happen on the latest firmware?
  • is a usb connected device involved?
  • is the router connected to a different power source other than the original one?
  • which router is it?
Usually if a house is very good isolated you can expect some issues, although since it is a appartment it should be normally 'ok', 2.4ghz is often the best to penetrate walls in my flat (i live 4th, i can even walk to my car some 15 meters away the flat and i'd still have internet on flint 2).
Though this wasn't always the case, once you have interference especially from things like a usb stick, that can cause the behaviour that wifi becomes really bad past the 8 meters it degrades, this seem to be close to your situation when i was in the kitchen (which is open to the living area but has a wall corner) nothing wanted to work, it is like a really low signal then for just one room.
If it is the case of usb, can you try without it? :wink:
It's worth noting that especially the interference was known on the 2.4ghz band, 5ghz seemed to be unaffected.
