I have the Brume2 and BerylAX.
The Brume2 uses .25% load of the 200%, where as the BerylAx uses 100% of 200%.
I did a soft reset on the BerylAX and same thing 80-100% usage.
Since they use the same chipset, is the wifi chip really hogging all the extra cpu load?
Wouldn’t this be concerning that half the system load is used by the router, not doing much.
