Thu Oct 20 12:01:12 2022 daemon.info apcli[29601]: scanning...
Thu Oct 20 12:01:17 2022 daemon.warn apcli[29601]: not found ap(draem_G)...re-scan in 60s
But when I found that your other ssid is “dream_B”, I start to think you mean just mis-spelled it.
No. it is not misspelled. It is actually named “draem_G”… (Maybe it’s a building owner’s mistake.)
Anyway, Yesterday I investigated this issue using another manufacturer’s router.
I got a hint from the fact that this issue mainly occurred in the building with the guest house. This issue was occurring regardless of region.
The reason is unknown, but DHCP at the parent AP was not working properly for routers with WiFi repeater features. So I was able to set it manually by referring to the gateway and subnet mask information on my Windows PC.
It seems to me that if the DHCP on the parent AP is broken, there is no way to manually set it up in my router (Mango). The log on my router says it is connected, but the web console says it is not connected, so I can’t set anything up.
And is there a way to debug AP that is not found on my router? My WiFi analyzer says the AP has a very strong signal.
