Why modify the MTU of the tailsacel0 interface?
We encountered two tailscale issues in March 2026 and August 2026.
Case 1:
MT3600BE (located in the USA)
MT3000 (located in India, as a tailscale exit node)
When configuring the MT3000 as the tailscale exit node on the MT3600BE, the MT3600BE's network only functions normally for about 1-2 minutes, after which the MT3600BE and all client devices lose network connectivity.
On the MT3600BE, disabling the setting of MT3000 as a tailscale exit node immediately restores the network.
Case 2:
MT3000 A (located in the UAE)
MT3000 B (located in India, as a tailscale exit node)
When another MT3000 B is configured as the tailscale exit node on the MT3000A, the network works normally for about 10-15 minutes, after which the MT3000A will lose network connectivity.
On the MT3000A, disabling the setting of MT3000 as a tailscale exit node immediately restores the network.
It is normal to set up the exit node using other devices such as mobile phones or computers during abnormal situations.
In both cases, the problem was solved by modifying the MTU of the tailscale0 interface.
Execute the following commands on the MT3600BE in Case 1 and the MT3000A in Case 2:
ip link set dev tailscale0 mtu 1100
The reason why the MTU must be modified is currently unclear and under investigation.
If you encounter a similar problem, you might try using this method to test if it works.
Iam also facing the same issue from AE to IN. After changing MTU issue solved.
But as per the speed test in AE the upload is lower than download. Almost half.
The below settings gives me much better experience from AE to IN with default MTU value.
Yes, this has always been the case. Recommend using custom DNS for Tailscale. But you can set manual DNS on the GL.iNet router as well which will override Tailscale's DNS anyway.
Interesting, that is quite a low MTU. I've not seen this before.
@steavejohn .. @AdamK is correct.. The GL TS init scripts bring up TS with "--accept-dns=false". Nothing you set on the Tailnet is used by the router. You'll want to set DNS on the router DNS setting to have an impact.
@lucas2 - I stuck our TS research agent on this thread that assists on our gl-tailscale-fix repo. Some initial thoughts (AI slop, but well trained TS specialist AI slop at least) :slight_smile:
A lower MTU may work as a stopgap, but I don’t think this shows it’s a path MTU problem yet.
  • Phones and computers worked as exit-node clients. Tailscale’s default MTU is the same 1280 there, so they should send the same size packets. If they were on the same uplink, that points at the router, not the path.
  • Other threads report Tailscale failing on the router’s own forwarding path: Beryl AX TSO/GSO, Beryl AX wired vs Wi-Fi, and BE6500 forwarded traffic, where ICMP passed up to 1280 and a lower MSS made it worse. Another BE6500 report has tailscaled itself dying. These may not be the same bug.
  • All three reports here use an exit node in India.
If anyone can reproduce it, these would help, captured at the default MTU while it’s failing:
  1. tailscale status: is the exit node direct or relay?
  2. dmesg | grep -E 'tun:|GSO', and whether the tailscaled PID changed
  3. From a LAN client: ping by IP (small and full size), and a lookup by name
  4. Wired client vs Wi-Fi client
  5. tailscale ping --size=1312 <exit node> (1340 bytes on the wire) and --size=1132 (1160), from both ends
If you do use 1100: HTTP/3 can’t pass, because QUIC needs at least 1228 bytes on IPv4, and TCP loses about 15% payload per packet.
I ran the diagnostics @rthco suggested on our setup, all at default MTU (1280 on tailscale0, never changed).
Setup: GL-MT2500 as the Tailscale client (fw 4.7.13, Tailscale 1.104.4-tiny), "allow LAN access" on, using as exit node:
  • A) a GL-MT6000 on the same LAN (fw 4.11.0, Tailscale 1.94.1-tiny), for 17 min
  • B) a Pixel 8a on a Korean mobile network (exit IP in Seoul, ~300-750 ms RTT), for 20 min
Sampled every 30 s, with tailscale ping every 2 min:
  1. tailscale status: direct in both cases for the whole test, never via DERP.
  2. dmesg | grep -E 'tun:|GSO': only the boot-time TUN line, nothing new. tailscaled PID unchanged throughout. TSO/GSO are off on br-lan and tailscale0 on these routers (GRO on).
  3. From the router: ping 1.1.1.1 0% loss in every sample, DNS lookups OK, HTTPS OK. From a wired LAN client: inside the tailnet, ping -M do -s 1252 passes and -s 1300 doesn't, consistent with the 1280 MTU.
  4. Wired vs Wi-Fi: not tested, no Wi-Fi client available remotely.
  5. tailscale ping --size=1312 and --size=1132: every ping got a pong, in both directions, with no difference between the two sizes.
No connectivity loss in either test, including the long-RTT one through Korea. So a far-away exit node with a direct path is not enough to trigger it here. What we did not reproduce from the original reports: a GL router acting as the remote exit node (the MT3000 in India), a path stuck on DERP, and runs longer than 20 min.
@ambrogio-olivaw - that rules out distance and latency alone on your setup. Two questions:
  1. Are TSO/GSO off on br-lan and tailscale0 by default on those routers, or is that your workaround from the BE6500 thread? Tailscale’s code turns TSO on for its interface by default, so if it’s your workaround, the results won't be the same path. Could you try the same with TSO back on?
  2. Did the size pings show via ip:port or via DERP? A pong through DERP doesn’t test the direct path.
