WiFi as a client and a hotspot at the same time
i need to share same WiFi (like i’ve got one login+password from my hotel) connection and use it on my laptop, mobile phone etc.
Is it possible with Gl-inet travel box hardware ?
This would not be a repeater mode. Maybe i simply need another WiFi hardware like usb stick ?
So on board WiFi whould go to AP Client mode and - second one into a AP and serve dhcp / do NAT etc?
Yes you can use the router.
Not sure why you call it not a repeater because it is simply is.
Thanks,
as for repeater mode i’ve used to simply have a wide wifi network (same dhcp, same subnet).
What i need is to NAT many clients for one IP.
which hardware you would recommend for this ?
In our firmware:
Repeater = connecting to one WiFi network and broadcast its own WiFi with NAT, also called wireless WAN
Extender = connecting to one WiFi network and make a bridge without NAT
The router support both.
And precise hardware type does not matter ?
Could it repeat (dhcp+nat) also on LAN ports, so on Mango GL-MT300N-V2, i’ve got - Wifi Client, Wifi Repeater and also a two ethernet ports for LAN?
if that is true - where should i buy it (EMEA, PL) ? Any official store ?
It is yes to your question.
You can go to www.gl-inet.com and find the sales channels.
