Wifi client without repeater on Baryl AX
Is it posible to use Baryl AX as wifi client (bridge to LAN ports) only, without retransmiting its own wifi network? I can make it as such in repeater mode, then disable wifi, but it stay connected only for a while or until the first restart. Then it dont connect to upstream wifi anymore without enabling wifi again.
I tested in MT3000 with v4.7.0 firmware, and disable all WiFi, and the repeater connected normal and re-connect normal when the router rebooted.
Cannot reproduce.
  1. please share the syslog
  2. SSH:
cat /etc/config/wireless
cat /etc/config/repeater
Checked twice, after repeated and after rebooting (cannot repeat).
I tried on 4.6.9 and then on beta 4.7.0. Upstream wifi is Flint2.
log.txt.zip (1.6 KB)
The configuration of the wireless and repeater seem does not issue.
But the syslog did not share with me, please PM me the syslog, export from GL GUI -> System -> Log.
Since I did not reproduce this issue in my router with v4.7.x, if possible please reset the MT3000 and try it one more time in the v4.7.0
