I have a GLS-1300 as my primary router, it’s operating in mesh mode with 2 GLN-1300’s operating as sub-nodes. Every 60 minutes the WiFi network “breaks” and temporarily stops working. It comes back in 1-2 minutes. I have rebooted the router, the problem persists it just resets the 60 minute timer. I have temporarily turned off both mesh nodes, the problem persists.
I am adding the syslog and kernel log from one of the “broken” times, I believe it’s happening at [32457.837461]
[32456.145372] EXT NSS Supported
[32456.148206] idx 1 req 2 num_units 1 num_unit_info 12 unit size 256 actual units 53
[32456.155805] ol_ath_alloc_host_mem_chunk req_id 2 idx 0 num_units 53 unit_len 256,
[32456.163452] idx 2 req 3 num_units 1 num_unit_info 12 unit size 1024 actual units 53
[32456.171207] ol_ath_alloc_host_mem_chunk req_id 3 idx 1 num_units 53 unit_len 1024,
[32456.178681] idx 3 req 4 num_units 1 num_unit_info 12 unit size 4096 actual units 53
[32456.186444] ol_ath_alloc_host_mem_chunk req_id 4 idx 2 num_units 53 unit_len 4096,
[32456.194028] idx 0 req 1 num_units 0 num_unit_info 2 unit size 744 actual units 531
[32456.201747] ol_ath_alloc_host_mem_chunk req_id 1 idx 3 num_units 531 unit_len 744,
[32456.209307] idx 4 req 6 num_units 35 num_unit_info 0 unit size 3072 actual units 35
[32456.217112] ol_ath_alloc_host_mem_chunk req_id 6 idx 4 num_units 35 unit_len 3072,
[32456.224696] idx 5 req 7 num_units 1 num_unit_info 0 unit size 6144 actual units 1
[32456.232316] ol_ath_alloc_host_mem_chunk req_id 7 idx 5 num_units 1 unit_len 6144,
[32456.239825] idx 6 req 5 num_units 0 num_unit_info 2 unit size 2028 actual units 531
[32456.247582] ol_ath_alloc_host_mem_chunk req_id 5 idx 6 num_units 531 unit_len 2028,
[32456.255192] Support not added yet for Service 91
[32456.259812] Support not added yet for Service 92
[32456.264390] No EXT_MSG send INIT now
[32456.267976] chunk 0 len 13568 requested , ptr 0x9b198000
[32456.273332] chunk 1 len 54272 requested , ptr 0x9abd0000
[32456.278738] chunk 2 len 217088 requested , ptr 0x9a440000
[32456.284188] chunk 3 len 395064 requested , ptr 0x9a480000
[32456.289677] chunk 4 len 107520 requested , ptr 0x9a500000
[32456.295122] chunk 5 len 6144 requested , ptr 0x9c3f0000
[32456.300438] chunk 6 len 1076868 requested , ptr 0x9a600000
[32456.306033] ol_ath_service_ready_event[4251] WAPI MBSSID 2
[32456.311718] smart_log_init: Smart logging Enabled buf=dad40000 (size=65536)
[32456.348796] Version = 16777216 3 status = 0
[32456.352078] ol_ath_connect_htc() WMI is ready
[32456.356427] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 1
[32456.356440] target uses HTT version 2.2; host uses 2.2
[32456.376370] wmi_unified_register_event_handler : event handler already registered 0x900b
[32456.383462] wmi_unified_register_event_handler : event handler already registered 0x9042
[32456.391690] >>>> CB Set (null)
[32456.394993] ol_ath_thermal_mitigation_attach: --
[32456.399377] ol_if_dfs_setup: called
[32456.399410] ath_sysfs_diag_init: diag_fsattr
[32456.403904] isCountryCodeValid: EEPROM regdomain 0x0
[32456.408657] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2) flags 0x2150
[32456.415693] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4) flags 0xa0
[32456.422720] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x8) flags 0xc0
[32456.429517] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x20) flags 0xd0
[32456.436595] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x40) flags 0x150
[32456.443395] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x800) flags 0x10080
[32456.450945] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2000) flags 0x20080
[32456.458295] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4000) flags 0x40080
[32456.465732] Add VHT80 channel: 5210
[32456.468876] Add VHT80 channel: 5290
[32456.472321] Add VHT80 channel: 5530
[32456.476050] Add VHT80 channel: 5610
[32456.479299] Add VHT80 channel: 5690
[32456.482753] Add VHT80 channel: 5775
[32456.486346] Skipping VHT80 channel 5825
[32456.490349] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x200000) flags 0x4000100
[32456.498069] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x400000) flags 0x8000100
[32456.507492] freq=58
[32456.508649] freq=106
[32456.510911] freq=122
[32456.513163] freq=138
[32456.540151] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg00000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000, cfgvalid[2] 10000
[32456.555133] smart_log_deinit: Smart logging Disabled
[32456.582405] set TXBF_SND_PERIOD: value 100 wmi_status 0
[32456.618381] Disconnect_timeout value entered:10
[32456.627606] reconfiguration_timeout value entered:60
[32456.900264] send_vdev_create_cmd_non_tlv: ID = 0 Type = 1, Subtype = 0 VAP Addr = 96:83:c4:01:85:8b:
[32456.908679] ieee80211_mbo_vattach:MBO Initialized
[32456.913150] ieee80211_oce_vattach: OCE Initialized
[32456.918586] __ieee80211_smart_ant_init: Smart Antenna is not supported
[32456.924665] Enabling TX checksum bit for the vap ath1 features 4000
[32456.931286] Enabling SG bit for the vap ath1 features 4000
[32456.936553] Enabling SG bit for the vap ath1 features 4000
[32456.942304] Enabling TSO bit for the vap ath1 features 4000
[32456.947906] Enabling LRO bit for the vap ath1 features 4000
[32456.955640] VAP device ath1 created osifp: (dd33d500) os_if: (db180000)
[32456.982543] siwfreq
[32456.983649] Set freq vap 0 stop send + db180000
[32456.988744] Set freq vap 0 stop send -db180000
[32457.017057] Set wait done --db180000
[32457.139059] [DEBUG] vap-0(ath1):set SIOC80211NWID, 9 characters
[32457.144625]
[32457.144625] DES SSID SET=Netgear01
[32457.787102] ieee80211_ioctl_siwmode: imr.ifm_active=66176, new mode=3, valid=1
[32457.837461] DEVICE IS DOWN ifname=ath1
[32457.840774] DEVICE IS DOWN ifname=ath1
[32458.097977] Sending SCAN START cmd
[32458.100554] 8021q: adding VLAN 0 to HW filter on device ath1
[32458.457510] device ath1 entered promiscuous mode
[32458.461264] br-lan: port 4(ath1) entered forwarding state
[32458.466585] br-lan: port 4(ath1) entered forwarding state
[32458.542946] send_vdev_create_cmd_non_tlv: ID = 1 Type = 1, Subtype = 0 VAP Addr = 9a:83:c4:01:85:8b:
[32458.551230] ieee80211_mbo_vattach:MBO Initialized
[32458.555846] ieee80211_oce_vattach: OCE Initialized
[32458.560990] __ieee80211_smart_ant_init: Smart Antenna is not supported
[32458.567392] Enabling TX checksum bit for the vap ath11 features 4000
[32458.573723] Enabling SG bit for the vap ath11 features 4000
[32458.579437] Enabling SG bit for the vap ath11 features 4000
[32458.585010] Enabling TSO bit for the vap ath11 features 4000
[32458.590855] Enabling LRO bit for the vap ath11 features 4000
[32458.598587] VAP device ath11 created osifp: (d8232500) os_if: (d76d0000)
[32458.631888] siwfreq
[32458.633068] Set freq vap 0 stop send + db180000
[32458.637625] osif_vap_acs_cancel: Scan in progress.. Cancelling it vap: 0xdb180000
[32458.645951] send_vdev_down_cmd_non_tlv for vap 0
[32458.649822] Set freq vap 0 stop send -db180000
[32458.677037] Set wait done --db180000
[32458.679605] Set freq vap 1 stop send + d76d0000
[32458.684343] Set freq vap 1 stop send -d76d0000
[32458.717029] Set wait done --d76d0000
[32458.748319] Sending SCAN START cmd
[32458.849021] [DEBUG] vap-1(ath11):set SIOC80211NWID, 12 characters
[32458.854100]
[32458.854100] DES SSID SET=f5bh6v74aWad
[32459.343679] Switching to Tx Mode-1 Threshold 280
[32459.477081] ieee80211_ioctl_siwmode: imr.ifm_active=66176, new mode=3, valid=1
[32459.507546] DEVICE IS DOWN ifname=ath11
[32459.510633] DEVICE IS DOWN ifname=ath11
[32459.727863] osif_vap_init: Scan in progress.. Cancelling it. vap: 0xd76d0000
[32459.757326] 8021q: adding VLAN 0 to HW filter on device ath11
[32460.259581] device ath11 entered promiscuous mode
[32460.263422] br-lan: port 5(ath11) entered forwarding state
[32460.268863] br-lan: port 5(ath11) entered forwarding state
[32460.456971] br-lan: port 4(ath1) entered forwarding state
[32462.266980] br-lan: port 5(ath11) entered forwarding state
[32466.110586] send_vdev_down_cmd_non_tlv for vap 0
[32466.114489] OL vap_start +
[32466.116931] VDEV START
[32466.119228] OL vap_start -
[32466.121938] ol_ath_vap_set_param: Now supported MGMT RATE is 6000(kbps) and rate code: 0x3
[32466.130401] OL vap_start +
[32466.132861] VDEV START
[32466.135201] OL vap_start -
[32466.137971] ol_ath_vap_set_param: Now supported MGMT RATE is 6000(kbps) and rate code: 0x3
[32466.206057] ME Pool succesfully initialized vaddr - d8e60000 paddr - 0
[32466.206057] num_elems = 1424 buf_size - 64 pool_size = 102528
[32466.217361] Enable MCAST_TO_UCAST
[32466.225635] ME Pool succesfully initialized vaddr - d8120000 paddr - 0
[32466.225635] num_elems = 1424 buf_size - 64 pool_size = 102528
[32466.236943] Enable MCAST_TO_UCAST
[32466.297629] ol_vdev_start_resp_ev for vap 0 (db924000)
[32466.301803] send_wmm_update_cmd_non_tlv:
[32466.305917] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 1
[32466.312781] send_vdev_up_cmd_non_tlv for vap 0
[32466.317162] Beacon mode set to staggered. Cannot enable FD
[32466.322578] __ieee80211_smart_ant_init: Smart Antenna is not supported
[32466.329250] ol_vdev_start_resp_ev for vap 1 (db924000)
[32466.334310] send_wmm_update_cmd_non_tlv:
[32466.338471] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 1
[32466.345288] send_vdev_up_cmd_non_tlv for vap 1
[32466.349759] Beacon mode set to staggered. Cannot enable FD
[32469.576369] [ath0] Band steering events being sent to PID:24154
[32469.581342] [ath01] Band steering events being sent to PID:24154
[32469.587324] [ath1] Band steering events being sent to PID:24154
[32469.593164] [ath11] Band steering events being sent to PID:24154
[32497.513755] Switching to Tx Mode-1 Threshold 0
[32503.744643] Getting extcaps from Scan Entry
[32503.747919] Getting extcaps from Scan Entry
[32504.318278] Switching to Tx Mode-1 Threshold 34
[32504.417815] Switching to Tx Mode-1 Threshold 0
[32513.313443] Switching to Tx Mode-1 Threshold 34
[32514.214134] Switching to Tx Mode-1 Threshold 0
[32540.297880] Switching to Tx Mode-1 Threshold 34
[32541.981720] Switching to Tx Mode-1 Threshold 0
[32552.291131] Switching to Tx Mode-1 Threshold 34
[32554.104626] Switching to Tx Mode-1 Threshold 0
[32576.182075] Getting extcaps from Scan Entry
[32576.185323] Getting extcaps from Scan Entry
[32576.277762] Switching to Tx Mode-1 Threshold 34
[32578.108840] Switching to Tx Mode-1 Threshold 0
[32578.175766] Getting extcaps from Scan Entry
[32578.179035] Getting extcaps from Scan Entry
[32579.276042] Switching to Tx Mode-1 Threshold 34
[32579.377705] Switching to Tx Mode-1 Threshold 0
[32581.170186] Switching to Tx Mode-1 Threshold 0
[32582.274088] Switching to Tx Mode-1 Threshold 34
[32582.387276] Switching to Tx Mode-1 Threshold 0
[32585.272655] Switching to Tx Mode-1 Threshold 34
[32585.325839] Switching to Tx Mode-1 Threshold 0
[32588.270948] Switching to Tx Mode-1 Threshold 34
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.540151] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg00000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000, cfgvalid[2] 10000
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.555133] smart_log_deinit: Smart logging Disabled
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.582405] set TXBF_SND_PERIOD: value 100 wmi_status 0
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.618381] Disconnect_timeout value entered:10
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.627606] reconfiguration_timeout value entered:60
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.900264] send_vdev_create_cmd_non_tlv: ID = 0 Type = 1, Subtype = 0 VAP Addr = 96:83:c4:01:85:8b:
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.908679] ieee80211_mbo_vattach:MBO Initialized
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.913150] ieee80211_oce_vattach: OCE Initialized
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.918586] __ieee80211_smart_ant_init: Smart Antenna is not supported
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.924665] Enabling TX checksum bit for the vap ath1 features 4000
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.931286] Enabling SG bit for the vap ath1 features 4000
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.936553] Enabling SG bit for the vap ath1 features 4000
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.942304] Enabling TSO bit for the vap ath1 features 4000
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.947906] Enabling LRO bit for the vap ath1 features 4000
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.955640] VAP device ath1 created osifp: (dd33d500) os_if: (db180000)
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.982543] siwfreq
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.983649] Set freq vap 0 stop send + db180000
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32456.988744] Set freq vap 0 stop send -db180000
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32457.017057] Set wait done --db180000
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32457.139059] [DEBUG] vap-0(ath1):set SIOC80211NWID, 9 characters
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32457.144625]
Mon Feb 7 17:47:57 2022 kern.warn kernel: [32457.144625] DES SSID SET=Netgear01
Mon Feb 7 17:47:58 2022 kern.warn kernel: [32457.787102] ieee80211_ioctl_siwmode: imr.ifm_active=66176, new mode=3, valid=1
Mon Feb 7 17:47:58 2022 kern.warn kernel: [32457.837461] DEVICE IS DOWN ifname=ath1
Mon Feb 7 17:47:58 2022 kern.warn kernel: [32457.840774] DEVICE IS DOWN ifname=ath1
Mon Feb 7 17:47:58 2022 kern.warn kernel: [32458.097977] Sending SCAN START cmd
Mon Feb 7 17:47:58 2022 kern.info kernel: [32458.100554] 8021q: adding VLAN 0 to HW filter on device ath1
Mon Feb 7 17:47:59 2022 daemon.notice netifd: Network device 'ath1' link is up
Mon Feb 7 17:47:59 2022 kern.info kernel: [32458.457510] device ath1 entered promiscuous mode
Mon Feb 7 17:47:59 2022 kern.info kernel: [32458.461264] br-lan: port 4(ath1) entered forwarding state
Mon Feb 7 17:47:59 2022 kern.info kernel: [32458.466585] br-lan: port 4(ath1) entered forwarding state
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.542946] send_vdev_create_cmd_non_tlv: ID = 1 Type = 1, Subtype = 0 VAP Addr = 9a:83:c4:01:85:8b:
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.551230] ieee80211_mbo_vattach:MBO Initialized
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.555846] ieee80211_oce_vattach: OCE Initialized
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.560990] __ieee80211_smart_ant_init: Smart Antenna is not supported
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.567392] Enabling TX checksum bit for the vap ath11 features 4000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.573723] Enabling SG bit for the vap ath11 features 4000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.579437] Enabling SG bit for the vap ath11 features 4000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.585010] Enabling TSO bit for the vap ath11 features 4000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.590855] Enabling LRO bit for the vap ath11 features 4000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.598587] VAP device ath11 created osifp: (d8232500) os_if: (d76d0000)
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.631888] siwfreq
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.633068] Set freq vap 0 stop send + db180000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.637625] osif_vap_acs_cancel: Scan in progress.. Cancelling it vap: 0xdb180000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.645951] send_vdev_down_cmd_non_tlv for vap 0
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.649822] Set freq vap 0 stop send -db180000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.677037] Set wait done --db180000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.679605] Set freq vap 1 stop send + d76d0000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.684343] Set freq vap 1 stop send -d76d0000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.717029] Set wait done --d76d0000
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.748319] Sending SCAN START cmd
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.849021] [DEBUG] vap-1(ath11):set SIOC80211NWID, 12 characters
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.854100]
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32458.854100] DES SSID SET=f5bh6v74aWad
Mon Feb 7 17:47:59 2022 kern.warn kernel: [32459.343679] Switching to Tx Mode-1 Threshold 280
Mon Feb 7 17:48:00 2022 kern.warn kernel: [32459.477081] ieee80211_ioctl_siwmode: imr.ifm_active=66176, new mode=3, valid=1
Mon Feb 7 17:48:00 2022 kern.warn kernel: [32459.507546] DEVICE IS DOWN ifname=ath11
Mon Feb 7 17:48:00 2022 kern.warn kernel: [32459.510633] DEVICE IS DOWN ifname=ath11
Mon Feb 7 17:48:00 2022 kern.warn kernel: [32459.727863] osif_vap_init: Scan in progress.. Cancelling it. vap: 0xd76d0000
Mon Feb 7 17:48:00 2022 kern.info kernel: [32459.757326] 8021q: adding VLAN 0 to HW filter on device ath11
Mon Feb 7 17:48:00 2022 daemon.notice netifd: Network device 'ath11' link is up
Mon Feb 7 17:48:00 2022 kern.info kernel: [32460.259581] device ath11 entered promiscuous mode
Mon Feb 7 17:48:00 2022 kern.info kernel: [32460.263422] br-lan: port 5(ath11) entered forwarding state
Mon Feb 7 17:48:00 2022 kern.info kernel: [32460.268863] br-lan: port 5(ath11) entered forwarding state
Mon Feb 7 17:48:01 2022 kern.info kernel: [32460.456971] br-lan: port 4(ath1) entered forwarding state
Mon Feb 7 17:48:02 2022 user.notice gl_monitor: dhcp-range for lan network is missing, restart dnsmasq
Mon Feb 7 17:48:02 2022 daemon.info dnsmasq[17761]: exiting on receipt of SIGTERM
Mon Feb 7 17:48:02 2022 kern.info kernel: [32462.266980] br-lan: port 5(ath11) entered forwarding state
Mon Feb 7 17:48:03 2022 daemon.err gl_monitor[6653]: udhcpc: started, v1.25.1
Mon Feb 7 17:48:03 2022 daemon.err gl_monitor[6653]: udhcpc: sending discover
Mon Feb 7 17:48:03 2022 daemon.err gl_monitor[6653]: udhcpc: sending select for 10.0.1.193
Mon Feb 7 17:48:03 2022 daemon.err gl_monitor[6653]: udhcpc: lease of 10.0.1.193 obtained, lease time 268435455
Mon Feb 7 17:48:03 2022 user.notice dnsmasq: found already running DHCP-server on interface 'br-lan' refusing to start, use 'option force 1' to override
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: started, version 2.80test3 cachesize 150
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: DNS service limited to local subnets
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq-dhcp[22887]: IPv6 router advertisement enabled
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: using local addresses only for domain test
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: using local addresses only for domain onion
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: using local addresses only for domain localhost
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: using local addresses only for domain invalid
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: using local addresses only for domain bind
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: using nameserver 10.0.1.200#53
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: using local addresses only for domain lan
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: read /etc/hosts - 1 addresses
Mon Feb 7 17:48:04 2022 daemon.info dnsmasq[22887]: read /tmp/hosts/dhcp.cfg02411c - 116 addresses
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.110586] send_vdev_down_cmd_non_tlv for vap 0
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.114489] OL vap_start +
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.116931] VDEV START
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.119228] OL vap_start -
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.121938] ol_ath_vap_set_param: Now supported MGMT RATE is 6000(kbps) and rate code: 0x3
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.130401] OL vap_start +
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.132861] VDEV START
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.135201] OL vap_start -
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.137971] ol_ath_vap_set_param: Now supported MGMT RATE is 6000(kbps) and rate code: 0x3
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.206057] ME Pool succesfully initialized vaddr - d8e60000 paddr - 0
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.206057] num_elems = 1424 buf_size - 64 pool_size = 102528
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.217361] Enable MCAST_TO_UCAST
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.225635] ME Pool succesfully initialized vaddr - d8120000 paddr - 0
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.225635] num_elems = 1424 buf_size - 64 pool_size = 102528
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.236943] Enable MCAST_TO_UCAST
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.297629] ol_vdev_start_resp_ev for vap 0 (db924000)
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.301803] send_wmm_update_cmd_non_tlv:
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.305917] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 1
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.312781] send_vdev_up_cmd_non_tlv for vap 0
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.317162] Beacon mode set to staggered. Cannot enable FD
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.322578] __ieee80211_smart_ant_init: Smart Antenna is not supported
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.329250] ol_vdev_start_resp_ev for vap 1 (db924000)
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.334310] send_wmm_update_cmd_non_tlv:
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.338471] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 1
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.345288] send_vdev_up_cmd_non_tlv for vap 1
Mon Feb 7 17:48:06 2022 kern.warn kernel: [32466.349759] Beacon mode set to staggered. Cannot enable FD
Mon Feb 7 17:48:10 2022 kern.warn kernel: [32469.576369] [ath0] Band steering events being sent to PID:24154
Mon Feb 7 17:48:10 2022 kern.warn kernel: [32469.581342] [ath01] Band steering events being sent to PID:24154
Mon Feb 7 17:48:10 2022 kern.warn kernel: [32469.587324] [ath1] Band steering events being sent to PID:24154
Mon Feb 7 17:48:10 2022 kern.warn kernel: [32469.593164] [ath11] Band steering events being sent to PID:24154
Mon Feb 7 17:48:22 2022 daemon.info hostapd: ath1: STA 68:54:fd:8e:df:1d IEEE 802.11: associated
Mon Feb 7 17:48:22 2022 daemon.info hostapd: ath1: STA 68:54:fd:8e:df:1d RADIUS: starting accounting session FB3E7DCE0585C4DC
Mon Feb 7 17:48:22 2022 daemon.info hostapd: ath1: STA 68:54:fd:8e:df:1d WPA: pairwise key handshake completed (RSN)
Mon Feb 7 17:48:34 2022 daemon.info hostapd: ath11: STA 9e:83:c4:04:dc:30 IEEE 802.11: associated
Mon Feb 7 17:48:34 2022 daemon.info hostapd: ath11: STA 9e:83:c4:04:dc:30 RADIUS: starting accounting session E9124FA0200211B4
Mon Feb 7 17:48:34 2022 daemon.info hostapd: ath11: STA 9e:83:c4:04:dc:30 WPA: pairwise key handshake completed (RSN)
Mon Feb 7 17:48:34 2022 user.notice gl_monitor: dhcp-range for lan network is missing, restart dnsmasq
Mon Feb 7 17:48:35 2022 daemon.info dnsmasq[22887]: exiting on receipt of SIGTERM
Mon Feb 7 17:48:36 2022 daemon.err gl_monitor[6653]: udhcpc: started, v1.25.1
Mon Feb 7 17:48:36 2022 daemon.err gl_monitor[6653]: udhcpc: sending discover
Mon Feb 7 17:48:36 2022 daemon.err gl_monitor[6653]: udhcpc: sending select for 10.0.1.193
Mon Feb 7 17:48:36 2022 daemon.err gl_monitor[6653]: udhcpc: lease of 10.0.1.193 obtained, lease time 268435455
Mon Feb 7 17:48:36 2022 user.notice dnsmasq: found already running DHCP-server on interface 'br-lan' refusing to start, use 'option force 1' to override
Mon Feb 7 17:48:37 2022 daemon.info hostapd: ath11: STA 9e:83:c4:09:05:87 IEEE 802.11: associated
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: started, version 2.80test3 cachesize 150
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: DNS service limited to local subnets
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq-dhcp[26829]: IPv6 router advertisement enabled
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: using local addresses only for domain test
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: using local addresses only for domain onion
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: using local addresses only for domain localhost
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: using local addresses only for domain invalid
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: using local addresses only for domain bind
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: using nameserver 10.0.1.200#53
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: using local addresses only for domain lan
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: read /etc/hosts - 1 addresses
Mon Feb 7 17:48:37 2022 daemon.info dnsmasq[26829]: read /tmp/hosts/dhcp.cfg02411c - 116 addresses
Mon Feb 7 17:48:37 2022 daemon.info hostapd: ath11: STA 9e:83:c4:09:05:87 RADIUS: starting accounting session 53847A4E4920A69B
Mon Feb 7 17:48:37 2022 daemon.info hostapd: ath11: STA 9e:83:c4:09:05:87 WPA: pairwise key handshake completed (RSN)
Mon Feb 7 17:48:38 2022 kern.warn kernel: [32497.513755] Switching to Tx Mode-1 Threshold 0
Mon Feb 7 17:48:40 2022 authpriv.info dropbear[27390]: Child connection from 10.0.1.11:43964
Mon Feb 7 17:48:40 2022 authpriv.info dropbear[27421]: Child connection from 10.0.1.12:33270
Mon Feb 7 17:48:41 2022 authpriv.notice dropbear[27390]: Pubkey auth succeeded for 'root' with key md5 af:7a:74:3a:ad:30:6a:55:ef:54:c1:6b:6c:cc:24:fa from 10.0.1.11:43964
Mon Feb 7 17:48:41 2022 authpriv.info dropbear[27390]: Exit (root): Exited normally
Mon Feb 7 17:48:41 2022 authpriv.notice dropbear[27421]: Pubkey auth succeeded for 'root' with key md5 16:19:5b:b8:94:1b:95:d4:75:2e:13:b5:8f:83:ac:21 from 10.0.1.12:33270
Mon Feb 7 17:48:41 2022 authpriv.info dropbear[27421]: Exit (root): Exited normally
Mon Feb 7 17:48:44 2022 daemon.info hostapd: ath1: STA dc:a6:32:22:4b:f9 IEEE 802.11: associated
Mon Feb 7 17:48:44 2022 kern.warn kernel: [32503.744643] Getting extcaps from Scan Entry
Mon Feb 7 17:48:44 2022 kern.warn kernel: [32503.747919] Getting extcaps from Scan Entry
Mon Feb 7 17:48:44 2022 daemon.info hostapd: ath1: STA dc:a6:32:22:4b:f9 RADIUS: starting accounting session 4FE50AD914EAECF4
Mon Feb 7 17:48:44 2022 daemon.info hostapd: ath1: STA dc:a6:32:22:4b:f9 WPA: pairwise key handshake completed (RSN)
Mon Feb 7 17:48:44 2022 kern.warn kernel: [32504.318278] Switching to Tx Mode-1 Threshold 34
Mon Feb 7 17:48:44 2022 kern.warn kernel: [32504.417815] Switching to Tx Mode-1 Threshold 0
Mon Feb 7 17:48:53 2022 kern.warn kernel: [32513.313443] Switching to Tx Mode-1 Threshold 34
Mon Feb 7 17:48:54 2022 kern.warn kernel: [32514.214134] Switching to Tx Mode-1 Threshold 0
Mon Feb 7 17:48:56 2022 authpriv.info dropbear[28839]: Child connection from 10.0.1.11:43966
Mon Feb 7 17:48:56 2022 authpriv.info dropbear[28894]: Child connection from 10.0.1.12:33272
Mon Feb 7 17:48:56 2022 authpriv.notice dropbear[28839]: Pubkey auth succeeded for 'root' with key md5 af:7a:74:3a:ad:30:6a:55:ef:54:c1:6b:6c:cc:24:fa from 10.0.1.11:43966
Mon Feb 7 17:48:56 2022 authpriv.info dropbear[28839]: Exit (root): Exited normally
Mon Feb 7 17:48:57 2022 authpriv.notice dropbear[28894]: Pubkey auth succeeded for 'root' with key md5 16:19:5b:b8:94:1b:95:d4:75:2e:13:b5:8f:83:ac:21 from 10.0.1.12:33272
Mon Feb 7 17:48:57 2022 authpriv.info dropbear[28894]: Exit (root): Exited normally
Mon Feb 7 17:49:07 2022 user.notice gl_monitor: dhcp-range for lan network is missing, restart dnsmasq
Mon Feb 7 17:49:08 2022 daemon.info dnsmasq[26829]: exiting on receipt of SIGTERM
Mon Feb 7 17:49:09 2022 daemon.err gl_monitor[6653]: udhcpc: started, v1.25.1
Mon Feb 7 17:49:09 2022 daemon.err gl_monitor[6653]: udhcpc: sending discover
Mon Feb 7 17:49:09 2022 daemon.err gl_monitor[6653]: udhcpc: sending select for 10.0.1.193
Mon Feb 7 17:49:09 2022 daemon.err gl_monitor[6653]: udhcpc: lease of 10.0.1.193 obtained, lease time 268435455
Mon Feb 7 17:49:09 2022 user.notice dnsmasq: found already running DHCP-server on interface 'br-lan' refusing to start, use 'option force 1' to override
Mon Feb 7 17:49:09 2022 daemon.info dnsmasq[30842]: started, version 2.80test3 cachesize 150
Mon Feb 7 17:49:09 2022 daemon.info dnsmasq[30842]: DNS service limited to local subnets
Mon Feb 7 17:49:09 2022 daemon.info dnsmasq[30842]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
