I have an GL-AR300M-lite router and want to do the following:
- connect the router to a wifi (password enabled)
- share the wifi connection using the router wifi access point with others without password protection (Free Wifi)
- as soon as somebody connects to the router wifi access point, he/she should be prompted to a specific welcome url in the browser
Is this possible with OpenWRT and the router firmware?
Regarding security issues: yes, normally I won’t do this (access point with no password).In my very specific case it is safe enough and the only way to achive what I need.
I am thankful for your advice!
Best regards
EDIT: it seems that the OpenWRT Package “nodogsplash” does something similar to what I need. Is this possible to run on that router?
