Wifi sometimes not working [GL-SFT1200]
Hello!
I'm using my router while logged in in a public wifi with a custom mac-adress.
Everything works perfect, but after some hours the wifi cannot be found with any device.
Sometimes the wifi comes back after some minutes, other times I have to reset / disconnect it from the power.
Task and other settings are off.
Just changed the mac-adress and wifi-settings.
Firmware is up to date.
Is there any solution or maybe could it be a hardware failure?
Thx
Connects to the public WiFi by Repeater mode, right?
  1. SSH to the router:
    ubus call network.wireless status
    iwinfo
  2. Please PM me the issue syslog.
Try to check why the WiFi radio disappears.
