Hello
I am using MT3000 and MT6000 as wifi connection point for my family
The speed using the cable is 2.5Gbps
I have set 160Mhz on both devices and set WPA3
But there is a significant difference between the wifi speed of MT6000 and MT3000, specifically the maximum speed I measured on MT3000 is 1.8Gbps, while MT6000 only achieves 600-700Mbps.
I also enabled hardware acceleration for both devices.
Can someone explain or guide me through the settings for the MT6000 to get maximum speed, I have checked the cable and it is Cat8
Thanks!
In comparative testing, are the WiFi channels of the two the same?
Can try changing the WiFi country code, like AU or US.
Can try using op24 firmware.
I set Chanel to automatic
Where can I change the US or AU area code
I changed the region but the problem doesn't seem to be resolved
Can you pls try fixed channels?
I selected all channels, but the maximum speed is only 1Gbps.
I also tried switching Wan 2 to Lan 2.5Gbps, and the Speedtest speed showed it reached 2,452Mbps. Maybe the 5Ghz wifi is having speed issues, it doesn't reach the speed I want.
I hope there is a solution to achieve maximum speed, optimize for my internet connection
I tested wifi with Samsung S24 Ultra and Lenovo Legion Y700 2025
Install offical Openwrt 23.05.5, change wifi country code to US with fixed channel, adjust wifi AQL and test.
From Voz with luv
Thanks thím.
Form BanhCuonChaMuc - Voz
