Will there be native support to expressvpn for routers other than Fortify (GL-MT6000)?
Currently using openvpn protocol which is not ideal, eager to see it coming. Thanks.
There is currently no announced schedule for bringing Fortify’s native ExpressVPN integration to other GL.iNet models. Also, Fortify’s integration uses WireGuard—not ExpressVPN Lightway—and can support OpenVPN; Lightway is not currently supported.
If you share the GL.iNet model you want to use, its available WireGuard/OpenVPN options can be checked more specifically.
Is there a hardware difference between the flint 2 and the fortify version or are they exactly the same but just a different firmware?
If it’s just a firmware difference, what is the benefit of getting the fortify version?
Fortify uses the same hardware as Flint 2 (GL-MT6000), with differences in software functions. The main benefits of Fortify are its native ExpressVPN integration and the included 12 months of ExpressVPN’s Advanced plan for new or returning users. Existing ExpressVPN subscribers can also use their current subscription.
Fortify’s integration currently uses WireGuard rather than Lightway and also supports OpenVPN. An active ExpressVPN subscription is required for its ExpressVPN service, although Fortify can operate as a regular Wi-Fi 6 router without one.
