I have an AppleTV inside my home network. Unlike an iPhone/iPad the AppleTV cannot establish a vpn connection so you can’t use services like NordVPN. Is it possible to connect via Ethernet a gl.inet router’s (not sure which one) WAN port, and then connect the AppleTV to this gl.inet router’s LAN port and use the gl.inet router to make the vpn connection?
In other words would I be able to configure a gl.inet router to connect to my NordVPN account and use a specific server so that my AppleTV will have all traffic going through that vpn?
This is doable, but Apple may lock you in the country associated with your Apple account and you may have to create a new Apple ID associated with the country that will connect to over VPN. This would be a hassle if you have paid subscriptions that have to be moved to a new Apple account:
For only this use case, you do not need a super powerful router, as long as you can get 25Mbps VPN speed for 4K TV. Take into account that Wireguard is faster than OpenVPN, but NordVPN does not support Wireguard on routers, so you can subscribe to a Wireguard provider or buy a more powerful router for NordVPN.
Another issue is if you want the Apple TV to sometimes use VPN and sometimes not, which may require switching Apple accounts each time. Roku stick is the same and locks you in the country associated with your Roku account, so I have 1 stick for U.S. and 1 stick for Canada.
NordVPN calls their proprietary Wireguard implementation “NordLynx” and they do not provide config files for routers to users. Some people have been able to “reverse generate” their own config files on Linux and sfiorini has developed a procedure and shell script (above post) that I have successfully tested, but this process is not supported by NordVPN.
Apple recommends 25Mbps for 4K TV, which is on the safe, conservative side. For OpenVPN, the GL-MV1000W Brume, GL-AX1800 Flint and GL-MT1300 Beryl are all advertised for >20Mbps speeds.
