Wire Guard Client Yellow
I have the 2 router set up server at home connected to my home router and then a second router that i ravel with as the client.
I have been traveling with my router for the last 3 weeks. This last trip i decided to turn off the router for the weekend came back home the agent (astrorelay) on my tunnel was disconnected. I was able to have family back home reconnect it and that usually allows for my client to to turn green. It has been showing no internet although I’m able to connect my devices to the airbnbs router here.
The client has been “yellow” but the server at home is “green”. I’m not that tech savvy so I’m not sure how to troubleshoot. I’ve rebooted at home router, I’ve added a new configuration file but nothing seems to work. I’m also getting a subnet error but don’t know how to begin to fix this.
Here are my config files:
Interface]
Address = 10.0.0.3/32
ListenPort =
PrivateKey= redacted
DNS = 64.6.64.6
[Peer]
AllowedIPs = 0.0.0.0/0,::/0
Endpoint = CoreenEHome.arlab1.cc:16566
PersistentKeepalive = 25
PublicKey = redacted
update to the latest firmware and remove listenPort option
