Wired Router with multiple ports?
Have you ever consider making a wired router with an integrated switch like MT7981 + MT7531 without wireless so I do not have to buy a separate switch for product like MT2500. Cudy has R700 but it's not an ARM SoC and not available in China.
Thank you for your suggestion.
We will pass it on to the product team for further consideration.
More ports than the Brume 3?
Yeah, according to mt7531's datasheet, it can go up to five 1G and a 2.5G LAN ports instead of 2 in Brume 3. And both chips are very cheap now and well supported by the upstream openwrt.
