I was using OpenVPN before with another router and want to switch to Wireguard. So I decide to try the GL-MV1000. (:
This is my setup:
Wireguard itself is working. I’m able to ping the internal interface 192.168.0.4.
The client with 192.168.0.150 is directly connected to the Brume and is also listed as a connected device.
But if I try a ping I got the message ‘Target port is not reachable’ and I’m not able to get access via browser to the clients interface.
By default, the firewall has an routing lan → wan/wireguard; wan → ‘reject’ and wireguard → wan/lan.
I should be able to access the LAN, no?
Or I have to do a special routing? I tried, but without success. ):
It will be great if someone has an idea.
Best regards,
Thomas
