Is it possible to setup wireguard client so that it reconnects with next server in server profile list automatically in case the server goes down?
I have AR750s and B1300.
You can write a shell script to do that if you can.
Is there any guide to follow, I’m a quick learner but will need something to start from
Only need to config the Button (Switch) left of the Power Button. Left switch Connection on, Right switch Connection off.
After Reboot or Reconnect - the Box will reconnect the Wireguard Connection (I hope).
But I am interrested on a script too.
